Monzerje
Junior Member level 3
- Joined
- Oct 22, 2017
- Messages
- 28
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Kuala Lumpur, Malaysia
- Activity points
- 244
Well, you don't show enough of your frequency range but it looks like your stopband attenuation is about -19 db.
Stop-Band attenuation is given by an offset frequency.For instance..
-30dB att. 1GHz off-set from center frequency..
Is the label position correct? and how it is grater then 30dB since the obtained value is -66dB?
Why did you place the marker at that frequency? To evaluate the stopband attenuation value, you need a specification for the stopband frequency range first.
Before using a tool whose output you don't understand, it would be better to study some technical literature.
The terms used to specify a filter can be found in every good filter book. Or read the user manual of the software.
stopband attenuation are two values:That's why I am asking about it, because I do not know how to find it from the graph
