Starting up SG3525 with auxiliary winding
tictac
Full Member level 5
Full Member level 5
Polland
Hi
I want to design half-bridge smps from 220 volts(AC) and with the output voltage at about 24 volts and 100 watt .
Vin=220 volts AC
Vout=24 volts DC
Pout=100 watt
I dont want to use more iron transformer for the supply voltage of the sg3525 and I want to use auxiliary winding for genetating 12 volts for supplying the sg3525.
Can I use this auxiliary winding? Please help me for doing this.
Regards,
This is a boostrap winding, which as you require, will supply the IC's operating current.
Before the unit starts operating though. you still require a startup circuit, which takes the high voltage rectified DC and drops it to the lower voltage required to start the IC.
The simplest implementation is a power resistor, a capacitor and a zener, as simple as that.
Having said this, when you do your calculations, you will realize that dropping from 310 to 10 volts DC with a startup current of 30 or more mA like the 3525, the resistor and zener will be very, very large.
This is because the SG3525 wasn't designed for transformerless line startup. Newer devices have startup currents of perhaps 1 mA or lower, allowing for much smaller components.
    V
    tictac
    Kunlefemi
Thanks you so much for the answer.
It is the bootstrap circuit.
Could you give me the newer devices that have lower startup current,please?
Regards
