How to use BCD 74LS47 and connect it to 7 segment ?
nofnof
Junior Member level 3
74ls47
hi everybody ,
i working in designing a memory system for AVR microcontroller , im facing a problem in the BCD 74LS47 it consists of 16 pins , 7 outputs , 4 inputs , vcc, ground, and 3 other pins , i have read all the data sheets for this chip and all of them are the same , i connect the 74LS47 exactly as the data sheets , and theres no output
as u see in the figure
the 3 pins LT,BI/BRO, and RBI must be not connected to anything ,
please help to make this chip works
thanks
7 segment 74ls47
74LS47 has open collector outputs ,you have to connect each output to a resistance say 150Ω and then to the 7 segment digits which should be a common anode one.
74ls47 and 7 segments
LT must connected to +5V and RBI must be connected to +5V.
74ls47 seven segment
For a brief test of all segments connect LT(lamp test) to 0V (other inputs do not matter). Once you have all segments tested, tied high LT and RBI. RBO can be left not connected ..
Don't forget about limiting current to each segment by adding adequate resistors(≈220Ω)!!!
