T
treez
Hello,
We need an isolated DCDC module to give 15V output from a 13V input. Its to provide isolated power to a DALI comms bus from a non mains isolated source.
We need full mains isolation. This is usually described as being able to withstand a hi-pot test at “3000VAC at 50Hz for one second”.
The Traco TEN 3-1213 DCDC module gives isolation of “1500VDC for one second”.
Do you think that this is therefore safe to use for our DALI comms bus? (ie, does it equate to full mains isolation)?
Traco TEN 3-1213 DCDC module datasheet:
https://www.farnell.com/datasheets/...086.845751712.1519485949-287702491.1506211291
