e-music
Member level 5
Hello guys,
I have got two old Sony CRT TV sets. KV-2165MT and KV-2162M9. They were both left off for so long in a relatively humid area (home is only 2 miles from beach). It seems the older one (KV-2162M9) was the last one standing before we move here.
Since we moved here, it's been working flawlessly for about few weeks, and its picture was really nice. Later, the TV started to take 5~10 mins to start up, and some times more. Few days later, it refused to work. I removed the power cord and kept it unplugged for about two days and when tested it later on, the TV started up normally. However, the following day, the TV refused to work at all. I tried to remove the cable for few days again, but that didn't work. The hair dryer trick didn't help either.
The TV is completely dead now. No picture, no audio, only the red power LED turns on for couple of seconds then goes off everytime I turn it on, with a faint hissing or clicking sound coming out of its speakers as it turns off. Red LED blinks as I press any button in the front panel, and it gives an indication when the max/min volume reached when I play with volume buttons. Now, the funny thing is, when we tested the other set (KV-2165MT) which looks much better, it has exactly the same symptom. Just like if it was an infection affected both sets somehow??!! :-D
Because they both had the same issue, and the KV-2165MT looks much better, I decided to start with that one first. The schematics file (scan) is attached, and here is a link for a service manual for a similar model, but this one is the original PDF so it's much clearer than the first one:
http://monitor.espec.ws/files/kv-2185_sony_chassis_g3e_110.pdf
I started off by cleaning the entire set with a hoover and all circuit boards with a special spray so I can see what's going on under all that dust. I tested the set after cleaning, of course, it's still dead. Well, the main board has turned very dark under the large resistors at the power supply area, but the fuse is still intact. No capacitor is found to be bulged, checked almost all diodes/caps for short or leakage, but nothing yet. Some were tested in circuit, and others were removed from circuit for test.
When I got to the horizontal deflection area, I found the whole part shorted out (2SD1878). I removed it from circuit and, yep it was shorted out. Replaced it with a new one, but the TV still refuses to work. But as far as I remember, when tested with all cables connected, I spotted some sparks around the posistor area, between the posistor and the big square white resistor. I removed the power cord, disconnected all cables, removed the flyback suction cup from the tube and covered it and continued testing with only the power cable connected to the main board.
At this stage, the main 300v capacitor was not holding any charge after turning the power off, and it is the case for the 160v cap in the secondary section. After keeping the power on for few minutes, the STRS6307 has become very hot. The posistor gets very hot, too, but I believe it's normal.
After spending several hours, I found a short across the C628 cap. Removed the cap but the short still there. Voltages around the photocoupler, regulator, and Q601, Q603 are not the correct ones as it seems in the schematic. Even removing the whole 9-pin regulator didn't help, until I removed the transformer, T601. Now the short has gone, the STRS6307 doesn't get hot after several minutes. Could it be the transformer?
By the way, there's a 5v around the uC and the IR-Sensor, but there's a whole section that has no voltage whatsoever, of course when the transformer was mounted on board. The transformer is removed now, but don't know what to do next? I have a new STRS6307 that I can try out, but it seems fine when the transistor was removed, though the voltages I read across its pins were around -50, not -76 as the schematic says.
Any ideas?
Any ideas?
