CataM
- Joined
- Dec 23, 2015
- Messages
- 1,275
- Helped
- 314
- Reputation
- 628
- Reaction score
- 312
- Trophy points
- 83
- Location
- Madrid, Spain
- Activity points
- 8,409
Hello everyone,
Attached is how the voltage switching of a clamped-inductive switching for a MOSFET really looks like. As shown, the voltage falls to a low value before finishing the whole plateau, in other words, only a part of the whole Qgd is needed to switch the voltage from the Bus voltage to a low value.
If one assumes that the voltage falls linearly to its low value (almost ON state voltage) after the whole plateau charge has given, then that results in overestimating the switching losses because we are overestimating the voltage fall/rise time.
I would like to know if anyone knows how to compute that "Q3" charge needed to bring the drain voltage to "Vx" or any rule of thumb of its estimation in order not to overestimate the switching losses, or if it is worth at all... or just go with the overestimation of the switching losses ?
Here is an intent of computing the Q3 charge using the IPB65R420CFD MOSFET because they are giving the switching times at a clamped-inductive test.
First, compute Qgd for the switching test given in datasheet i.e. VDD=400V, ID=5.2A, Vgs=13V, Rg=3.4 ohms.
Qgd@Vdd=400V = Qgd@480V - (80*5pF+80*0.5pF/2)=18.6 nC - 0.42 nC=18.18 nC
Second, compute the charge needed to switch the Vds from 90% to 10% which is given in the switching test. Q3@Vdd=400V =tr(datasheet) * Igate=7ns * (13-6.4)/3.4 =13.6 nC which is about 3/4 of Qgd@Vdd=400V.
Any comment on this is much appreciated !
