garvind25
Full Member level 3
I was planning to interface a VGA port with a Xilinx CPLD. I went across several schematics available at digilent site. In one schematic here, one I/O pin each (of FPGA) is assigned to Red, Green and Blue channels. In another schematic here 3 I/O pins are assigned to Red and Green channels and 2 I/O pins to Ble channel. Next, in yet another schematic here 4 I/O pins are assigned to Red, Green and Blue channels.
**What could be the reason pls. ? Are multiple pins for 256 colour display? If not (I am tempted to guess otherwise as all the 3/4 pins are tied to single pin of the DB15 female connector), can I simply use one pin per channel and get the same output on VGA display instead of 2/3/4 pins per channel?
** Also, how were these resistance values calculated ? Is there any standard which governs the resistance value of the interfacing of the VGA port ?
Thanking You,
Arvind Gupta
Thanking You,
Arvind Gupta
