Basic concept of keypad
vead
Full Member level 5
Full Member level 5
india
Hello
I am looking help in programming to interface keypad. I have seen many example on internet. I can't understand. I want that when I press any button on keypad. it should be display on LCD. let's suppose I have matrix keypad 16x2 LCD display and 8051
This is routine to read keypad
char Read_Keypad()
  C1=1; C2=1; C3=1; C4=1;
  R1=0; R2=1; R3=1; R4=1;
  if(C1==0){Delay(100);while(C1==0);return '7';}
  if(C2==0){Delay(100);while(C2==0);return '8';}
  if(C3==0){Delay(100);while(C3==0);return '9';}
  if(C4==0){Delay(100);while(C4==0);return '/';}
  R1=1; R2=0; R3=1; R4=1;
  if(C1==0){Delay(100);while(C1==0);return '4';}
  if(C2==0){Delay(100);while(C2==0);return '5';}
  if(C3==0){Delay(100);while(C3==0);return '6';}
  if(C4==0){Delay(100);while(C4==0);return 'X';}
	R1=1; R2=1; R3=0; R4=1;
  if(C1==0){Delay(100);while(C1==0);return '1';}
  if(C2==0){Delay(100);while(C2==0);return '2';}
  if(C3==0){Delay(100);while(C3==0);return '3';}
  if(C4==0){Delay(100);while(C4==0);return '-';}
  R1=1; R2=1; R3=1; R4=0;
  if(C1==0){Delay(100);while(C1==0);return 'C';}
  if(C2==0){Delay(100);while(C2==0);return '0';}
  if(C3==0){Delay(100);while(C3==0);return '=';}
  if(C4==0){Delay(100);while(C4==0);return '+';}
  return 0;
Now I want to make routine that will store the number of keypad. Ho to routine that will store the numbers of keypad?
The keypad is arranged with the keys in a matrix or rows and columns. Each key is a switch that joins the row to the column where they intersect when it is pressed.
It scans the keypad by outputting one of the rows = 0 while the other three are high and then moves to the next row. So the row signals are:
0111
1011
1101
1110 <- note the '0' changes position each time.
So if one of the keys is pressed, the '0' will be connected to the column 'C' input where if gets found by the 'if(....' statement.
The delay is a crude way of de-bouncing the key by checking it is held down for at least 100mS, after then the 'while(...' statement loops until the key is released.
Depending on which row was '0' and which column detected it, the key can be identified and it's ASCII value returned. If no key is pressed it returns value zero.
Note that it isn't a particularly good way to do it for several reasons:
1. It doesn't return a key value until the key is released, normally you want it when it is pressed.
2. It is a blocking routine, it holds the program when a key is down.
3. Assigning a value to C1,C2, C3 and C4 is meaningless as they need to be inputs from the keypad. (pull-up resistors needed on the C inputs!)
4. It has no way of checking if more than one key is down and unless externally protected it could damage the row output drivers.
5. It can be written more efficiently using an array of look-up values.
Brian.
Reactions: Garyl and vead
    vead
    Garyl
Brian.
Thanks for your response. I don't have idea How to do it in best way? It will be appropriate if you can guide me. I am not asking for whole program. My main purpose is to understand keypad reading and storing. I want to understand keypad interfacing program.
array
unsigned char array [] = {key1, key2, key3,  key4, key5, key6,  key7, key8, key9, key10,  key11, key12, key13, key14, key15, key16};
How to make routine that will read the keypad?
How to make routine that will get number from keypad ?
Long story short, the best way is using bitmasking, I mean, operate directly on bits. You know how a single byte (8 bits) descirbes the state of the PORT? You can use that words directly to check the inputs.
Anyway, I'd suggest you reading a tutorial, for instance: https://www.8051projects.net/keypad-interfacing/introduction.php
They have both ASM and C code:
https://www.8051projects.net/keypad-interfacing/avr-programming.php
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
.include "8515def.inc"
.equ col1 = PINA0
.equ col2 = PINA1
.equ col3 = PINA2
.equ col4 = PINA3
.def keyval = r16
.def temp = r17
.def flags = r18
.equ keyport = PORTA
.equ pressed = 0
key_init:
        ldi keyval,$F0          ;Make Cols as i/p
        out DDRA, keyval        ;and Rows as o/p
        ldi keyval,$0F          ;Enable pullups
        out keyport, keyval     ;on columns
        ret
get_key:
        ldi keyval,$0           ;Scanning Row1
        ldi temp,$7F            ;Make Row1 low
        out keyport,temp        ;Send to keyport
        rcall read_col          ;Read Columns
        sbrc flags,pressed      ;If key pressed
        rjmp done               ;Exit the routine
        ldi keyval,$4           ;Scanning Row2
        ldi temp,$BF            ;Make Row2 Low
        rjmp done               ;Exit from routine
        ldi keyval,$8           ;Scanning Row3
        ldi temp,$DF            ;Make Row3 Low
        rcall read_col          ;Read columns
        ldi keyval,$C           ;Scanning Row4
        ldi temp,$EF            ;Make Row4 Low
        out keyport,temp        ;send to keyport
done:
        ret
read_col:
        cbr flags, (1<<pressed) ;Clear status flag
        sbic PINA, col1         ;Check COL1
        rjmp nextcol            ;Go to COL2 if not low
hold:
        sbis PINA, col1         ;Wait for key release
        rjmp hold
        sbr flags, (1<<pressed) ;Set status flag
        ret                     ;key 1 pressed
nextcol:
        sbic PINA,col2          ;Check COL2
        rjmp nextcol1           ;Goto COL3 if not low
hold1:
        sbis PINA, col2         ;Wait for key release
        rjmp hold1
        inc keyval              ;Key 2 pressed
        sbr flags,(1<<pressed)  ;Set status flag
        ret
nextcol1:
        sbic PINA,col3          ;Check COL3
        rjmp nextcol2           ;Goto COL4 if no pressed
hold2:
        sbis PINA, col3         ;Wait for key release
        rjmp hold2
        inc keyval              ;Key 3 pressed
        inc keyval
        ret
nextcol2:
        sbic PINA,col4          ;Check COL4
        rjmp exit               ;Exit if not low
hold3:
        sbis PINA, col4         ;Wait for key release
        rjmp hold3
        inc keyval              ;Key 4 Pressed
        inc keyval
        inc keyval
        ret
exit:
        clr keyval              ;reset keyval
        cbr flags, (1<<pressed) ;No Key Pressed
        ret
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
#include <avr/io.h>
        // Include file for AVR
#define keyport PORTA       //Keypad Port
#define keyportddr DDRA     //Data Direction Register
#define keyportpin PINA     //Keypad Port Pins
#define col1 PA0        //Column1 PortA.0
#define col2 PA1        //Column2 PortA.1
#define col3 PA2        //Column3 PortA.2
#define col4 PA3        //Column4 PortA.3
#define TRUE 1
#define FALSE 0
unsigned char keyval;   //A variable
| Prototype: void key_init(void);       |
| Return Type: void                     |
| Arguments: None                       |
| Description: Initialize ports and     |
|              Keypad.                  |
void key_init(){
    keyportddr = 0xF0;
    keyport = 0x0F;
| Prototype: unsigned char get_key(void);       |
| Return Type: unsigned char                    |
| Arguments: None                               |
| Description: To read key from the keypad      |
unsigned char get_key(){
    unsigned char i,key=1;
    for(i=0;i<4;i++){       //Loop for 4 rows
        keyport &=~(0x80>
i); //Make rows low one by one
            if(!(keyportpin & (1<<col1))){
             //check COL1
                while(!(keyportpin & (1<<col1)));
                //wait for release
                return key;
                //return pressed key value
            if(!(keyportpin & (1<<col2))){
             //Check COL2
                key += 1;
                //Second key pressed
                while(!(keyportpin & (1<<col2)));
                //wait for release
                return key;
                //return key value
            if(!(keyportpin & (1<<col3))){
             //Check COL3
                key += 2;
                //Third key pressed
                while(!(keyportpin & (1<<col3)));
                //Wait for release
                return key;
                //Return value
            if(!(keyportpin & (1<<col4))){
             //check COL4
                key += 3;
                //Fourth key pressed
                while(!(keyportpin & (1<<col4)));
                //Wait for release
                return key;
                //Return key value
        key +=4;    //Next row
        keyport |= 0x80>
i;
        //make read row high again
    return FALSE;   //return false if no key pressed
Still, at first you must understand how bitwise operators works in C. You must know what &, |=, << are doing. If you don't know thoes operators, you should first read about them and then proceed to keyboard stuff.
PS: I really admire the betwixt's patience to explain stuff to newbies!
Reactions: vead
    vead
