T
treez
Hello,
Our contractor tells us that we cannot use a 400V TVS in our offline (216-265VAC) Power factor corrected LED driver.
He says that we will need to use the 440V TVS of the same family, since he says that the 400V TVS would be damaged by the leakage current that it would experience.
Here is the SMCJ family TVS datasheet:
https://m.littelfuse.com/~/media/el...s/littelfuse_tvs_diode_smcj_datasheet.pdf.pdf
Our contractor insists that we must use the SMCJ440A instead of the SMCJ400A. Surely the SMCJ400A conducts less than 1mA of leakage current all the way up to 447V, and so should be fine?
The schematic of where we use the TVS is as attached.
