T
treez
Hello,
I went to disconnect the BNC of a coaxial probe from the scope, and received a snappy electric shock. Do you know why?
I have been disconnecting this same BNC connector on previous days, and wasnt electrocuted, even with the same overall setup.
I had to disconnect the BNC with the circuit "live", so i could not switch everything off to do the disconnection.
At first i couldnt touch the BNC because of the shocks.....then i kind of "pawed" at the BNC, touching it lightly then off again, then i was able to disconnect it without getting shocked.
The setup is as attached.
