Armand86
Newbie level 3
hello, i need help with VHDL sequence detector (101) project. I wrote VHDL file but output dout goes to 1 when machine is on "Next state" and not on "Present state". In other words machine gives output 1 on the falling edge of clock and not rising edge. anyone can help me? thanks
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity riconoscitoremealy is Port ( clk : in STD_LOGIC; din : in STD_LOGIC; rst : in STD_LOGIC; dout : out STD_LOGIC); end riconoscitoremealy; architecture Behavioral of riconoscitoremealy is type state is (st0, st1, st2); signal present_state, next_state : state; begin syncronous_process : process (clk) begin if rising_edge(clk) then if (rst = '1') then present_state <= st0; else present_state <= next_state; end if; end if; end process; next_state_and_output_decoder : process(present_state, din) begin dout <= '0'; case (present_state) is when st0 => if (din = '1') then next_state <= st1; dout <= '0'; else next_state <= st0; dout <= '0'; end if; when St1 => if (din = '1') then next_state <= st1; dout <= '0'; else next_state <= st2; dout <= '0'; end if; when St2 => if (din = '1') then next_state <= st1; dout <= '1'; else next_state <= st0; dout <= '0'; end if; when others => next_state <= st0; dout <= '0'; end case; end process; end Behavioral;
