finding VGS value for diode connected MOSFET
kiransbaddi
Member level 2
Member level 2
please help me find the value of VGS
I = ( V1 - V_gs) / 10k (calculated with the voltage across R which depends on V_gs)
And the mosfet has it's own characteristic.
I mainly depends on V_gs, but also on V_ds.
Now you have two I, both needs to be equal.
You can solve this mathematically or by drawing a chart.
Klaus
    V
You have the MOSFET inverted, so the MOSFET will conduct through the substrate diode.
Since you have the gate tied to the source the Vgs is zero.
For a diode-connected MOSFET you would invert the MOSFET with the gate still connected to V1.
In that case Vgs would be slightly above its threshold voltage.
As mentioned by crutschow, the substrate connection has to be corrected.
For a first order estimation, solve the idealized quadratic MOSFET equation.
