Sharagim
In this schematic when VCC feed with less than 1AMP mosfet getting HOT in some seconds and will burn if wont stop VCC(even if I feed with 300mA it will get HOT and blow), At this stage I see voltage drop so the Gate voltage will be something like 3~4V and seems the Mosfet is not ON completely.
If I feed with high current then I see it will take full load for a few milliseconds and then will go normal, continuously the current will be 200mA.
I think the problem is that the system couldn't bring the mosfet ON completely and as it is partially ON this problem occur!
