36W FTL Electronic ballast- usage of other wattage lamp
saumya_85
Full Member level 1
INDIA
FTL Electronic Ballast
I have a 36W FTL Electronic ballast. Could it be possible to put any other wattage lamp to its output?
lower u can use, for higher wattage lamp you need to modify ballast
Can we connect 2X18W instead of 36W FTL Electronic Ballast?
Why not? 2x18W is theoretically the same as 36W. It should work.
Added after 15 minutes:
Just make sure you connect the two lamps in parallel, that is across each other.
I have some doubt for the ignition of the two lamps.
How can be it is possible ?
