electronicsman
Full Member level 5
One clarification would help me a lot. I am referring to the following attached document which controls the PMSM motor using sinusoidal signal. I measure the current speed using the hall sensors and read the set reference speed and adjust the amplitude of the sine signal. I calculate the frequency of the signal based on hall signal and generate the sine wave of the same frequency by switching the legs. My doubt is I can generate the sine wave using a look up table then why the document is referring to space vector PWM? What exactly is space vector pwm? I am not able to understand the timing calculations of space vector pwm. Please help.
