julian403
Full Member level 5
Hello, I have to analize the boost dc-dc converter.
This has two operation mode. One when the transistor is on and second when transistor is off.
When transistor is on, in the first mode. The ecuation is:
\[ V = {r}_{on} {i}_{1}(t) + L \frac{d {i}_{1}(t)}{dt}\] where \[{r}_{on} = 0.01 \Omega \]
And the second mode it's
\[ V + L {{i}_{1}}^{0-} = L \frac{d {i}_{2}(t)}{dt} + R {i}_{2}(t) + \frac{1}{C} \int {i}_{2}(t) dt + \frac{{{i}_{2}}^{0-}}{C}\]
The problem here is the initial condition \[{i}_{1}^{0-}\] and \[{i}_{2}^{0-}\]of the diferential ecuation which it's growing until it reaches to the permanet condition.
How many step I must consider? because there is two times constants. One for the first mode's circuit and other for the second mode's circuits. For the firts mode circuit the time constant is L/r_on and for the second mode's circuit is ≈ Π/(RC) that's because it's a second order's system.
I need to know that for example if there is the need to know if the circuit is a continouos current or discontinouos current.
