bio_man
Full Member level 2
Hello folks,
I am using MOSFET as switch and I want to find the switching power loss.
Looking to the dynamic characteristics in dataSheet of any MOSFET, there is these four timing parameters:
td(on) == time to charge Ciss and pull Vgs up to Driving signal level. (Vds does not change, Ids=0)
tr == MOSFET now is conducting, Ids starts to rise and Vds starts to fall to zero.
td(off) == time to discharge Ciss ( Ids stays the same, Vds=0)
tf == MOSFET is turning OFF, Vds start rising and Ids falls to zero.
considering these states, it means we have only two states for switching Power Loss:
1) Psw(on) == during tr only (I assume tr is meant for current rise time, because usually it is much higher than tf)
1) Psw(off) == during tf only
Does my assumptions make sense? because I saw some references found Ton and Toff which are,
Ton=Td(on)+tr
Toff=Td(off)+tf
and then found Psw(on) and Psw(off) based on these timings, which I believe incorrect because in both, Td(on) and Td(off), one parameter is zero, Vds or Ids, so there is NO power loss!.
what do you think guys?
Ton=Td(on)+tr
Toff=Td(off)+tf
