It can not be calculated.
For an ideal pulse the timeis considered to be zero.
But it depends on the driver capabilities what's the real value.
It is totally independent of frequency, duty cycle and voltage.
Klaus
These are just a few, from RC + 3 inverters, single op amp, logic + crystal/logic + RC, two transistor + RC oscillators, the CD4060/HEF4060 + crystal/RC, a VCO IC, ..., ..., and there are plenty more. The "Relaxation Oscillators" pdf has the one using a single op amp and a few discrete components. Not sure why a 555 is not suitable, it's one of the simplest solutions to get a 1kHz, 70% duty cycle and makes it easy to adjust "on" and "off" time.
Make a basic OP/comparator based relaxation oscillator https://en.wikipedia.org/wiki/Relaxation_oscillator#Comparator.E2.80.93based_relaxation_oscillator
Adjust the duty cycle by moving the comparator threshold up or down (connect the resistor in the lower a left not to ground but to an offset voltage).
I don't think that's so, but I don't know what you mean by "ln2". And the "Relaxation Oscillators" pdf puts f = 1/1.4CR, look at the picture below. You could read pages 5 and 6 if you want to do the BJT version rather than an op amp version as described in the post above yours, there are more pleasant versions of the basic BJT one, such as "Variable Mark to space Ratio."
how i can calculate rise and fall time of a pulse with this specification...
sry i couldnt understand Pulse Techniques in colleje very well...
i don´t think the calculation is correct.
