julian403
Full Member level 5
rd is a resistor. Impossible to be admittance since admittance is measured in siemens.I think rd is output admittance, so where is the output conductance?
I think is the reciprocal of impedance.The admittance is the reciprocal of the conductance.
Did you notice the different measurement frequencies? Both specifications can't be compared at all.So I think there is the difference but the admittance (which in the parameter's table is the module) must be bigger than conductance and I do not know why it's not.
The simple model doesn't help because it ignores any reactant circuit elements.In the ac model which one I must use as rd?
You are right!Did you notice the different measurement frequencies? Both specifications can't be compared at all.
Yes, it's just a simple model which I found in internet. I'm using all capacitance in it. The input capacitance which it's between gate and source, outpu capacitance which it's between drain and source and the reverse transfer capacitance which it's between gate and drain.The simple model doesn't help because it ignores any reactant circuit elements.
Input capacitance is not Cgs, output capacitance is not Cds. Ciss = Cgs+Cgd, Coss=Cds+CgdThe input capacitance which it's between gate and source, outpu capacitance which it's between drain and source and the reverse transfer capacitance which it's between gate and drain.
