[SOLVED] Do we need an anti aliasing filter in front of a delta-sigma ADC?
CHL
Member level 3
Member level 3
Hello
I have a question about anti-aliasing filter (maybe stupid question)
If the sampling frequency is very high comparing to the input signal frequency, basically there is no aliasing, right?
A delta-sigma ADC is an oversampling ADC, so the sampling frequency is high depending on OSR.
I don't understand why an anti aliasing filter is used in front of the delta-sigma ADC.
Is it because of input noise? or any other reasons?
Yes, it's for noise.
Any noise above 1/2 the sample frequency will be aliased into the passband.
But all you generally need is a simple one-pole RC low-pass filter with a corner frequency some above the highest signal frequency to perform the anti-alias function.
Reactions: CHL and erikl
    erikl
    CHL
In addition, there are two flavor of delta sigma ADC. Discrete time and continuous time.
Continuous time has inherent anti-aliasing.
Reactions: CHL
    CHL
I don't call it noise. For me noise is a random signal with random frequencies.
The anti aliasing filter is for any signal above f_sample/2. Noise or any other signal.
And yes, I always recommend to use an anti aliasing filter.
In your case, where the sampling frequency is far above your signal of interest...it's just a simple RC.
Imagine.
Usually in a delta sigma ADC there is a (digital) low pass filter. It attenuates frequencies between datarate/2 up to f_sample/2.
But a signal above f_sample/2 will be aliased.
It may be real noise, some influence (noise) from an SMPS, influence from bluetooth, cellular phone, WiFi...
--> an anti aliasing filter definitely is useful.
Klaus
Reactions: CHL
    CHL
