eng_ibrahim
Member level 1
I want to know in CAN and LIN which one full duplex and half duplex
Did you read any documents about CAN and LIN?
Wikipedia?
Or the CAN bus specification from BOSCH?
Do the same with LIN.
There are a lot of PDFs ..even power point files
Klaus
The answer is simple and can be given by thinking quite a bit. Full duplex is only possible with separate communication channels for RX and TX, as e.g. RS-232 has it. Neither LIN (single line) nor CAN (single differential pair) does provide it.
