thanks for your reply....
yes,testability measurement means that for calculate test coverage and also Controllability,observability measures & estimation of test vector length.......
Your answer is confusing to me!using various faults to calculate the fault coverage,point of Controllability,point of observability measurements & estimation of test vector length....
Do you aim to perform "testability measurement" for a synthesized design *before* the insertion of scan chains?
all the major EDA companies have some tool that will do that for you. you can even do some analysis inside the synthesis tool to improve the observability if you want to.
