sharikbaig
Member level 1
Hi, Hope you all are doing good,
Say I have a PCB, a through hole one and i want to convert the same into SMT using as much SMD's as possible. Now the question is, are series & parallel passive component values same for SMD's? For example, if i used a 330 Ohm resistor in series with a LED to attain a specific brightness at 5V, in SMT will that resistor be of 330 Ohms or will these values change? Are current ratings of all SMD's are same as Through hole devices? And as we know 78XX series usually require heat sink, sure there isn't any provision to attach heat sink to a 78XX in SMD form, so how do we tackle the heating, or does it not heat in SMD package?
Apart from these, are there any more similar complications?
Thanks in advance
Thanks in advance
