36 volt smps design problem
rozmad
Junior Member level 2
hi
Im design a smps 36v 4a by piexpert but I have two problem
1-chock have a noios tik tik tik ....
2- output is 36v but current has very low amper about 100ma
help me
  • sch.pdf
Man, i have made a fast checking and i don't have found problems..
But about the low amperage, can be de inductor wire.
What wire gauge you are using for the inductor?
Reactions: rozmad
    rozmad
check the transformer
Reactions: rozmad
    rozmad
hi
transs specification
  • TOPSwitch-GX_PIDesign2.pdf
checked the transformer?, use proper varnish and try
Reactions: rozmad
    rozmad
TOP devices are sensitive to the amount of primary winding inductance.
I once had a similar problem and after redesign of my transformer to get the primary inductance in the range suggested by the ap note it started up with no problem.
Before that it just tic, tic as you describe.
Reactions: rozmad
    rozmad
thank from all
my design not worked Im continue
Im need the 35volt 3a smps very easy design same to me
thank from all
