Common circuit block in Altium
T
treez
Newbie level 1
Hello,
I have a schematic in Altium which has a main page schematic , and then four pages which comprise the same circuit block four times over, but with different connections in to them.
Do you know of a good tutorial which will allow me to make a “common block” out of the common schematic bit, so that I can use that instead of having to have the same circuit block four times?
Do you need is to replicate the original circuit several times but having different designators, or do you need that all the components at each one of these boards will have the same designator number ? In the case of the 1st scenario above you should take advantage of the "Multi-SheetDesign" feature available on Altium:
This way you can keep a single source of the original circuit so that changes performed there wiil be replicated over each instance on the PCB.
Reactions: renspci and treez
    T
    renspci
    V
Thanks I looked at that but it uses the “REPEAT” command, and my boss doesn’t want to use that. Basically we have a connector on the master sheet with 32 port things coming off it…each port has a different name.
We then have the 1 schematic sheet with the circuitry to be repeated (4 times)
The schematic with the repeat circuitry only connects to 8 of the ports on the connector of the master sheet.
But each repeat version of the repeated schem connects to a differet eight of the ports on the master sheet.
How do we do this?
The “edafile” attached shows the circuitry to be repeated.
The “eda Load Board” attached shows the ports at the connector
The “eda Load Block Top Level” shows the four instance of the circuitry, however, how do we make the given port attach to the right place on the circuitry-to-be-repeated without actually drawing ti four times over?
  • eda Load Block Top Level.pdf
  • eda Load Board.pdf
  • edafile.pdf
