velu.plg
Member level 5
i need to know how to get the interaction details between different subsystems because am going to floor plan my design.
tool used : vivado 2014.4
Just because they communicate often doesnt mean they need to be close to each other on the chip. If they communicate often at 25Mhz then they could be on opposite sides of the chip and still probably meet timing.
Why are you trying to do floor planning? this should only be needed if you are struggling to meet timing.
Can't you set commands in the XDC to specify placement of the cells?The purpose of the above question is if two subsystem communicate often in the sense i need to place this two as much as nearest.
:shock:we have 16 subsystems which have around 40 clocks
Exactly! my design doesn't met timing.we have 16 subsystems which have around 40 clocks
