microstrip radial stub
spide
Member level 3
Member level 3
radial stub
hi can anyone,provided me based concept on radial stub?i am using ADS to simulate.i have tried to search a lot of book in library but still couldnt find relevent topic.
Radial stub is born to realize a "short circuit" at the point where it's placed.
Because in planar circuits a true short require an extra work (i.e. metalizzed via hole), a way that not require via hole is preferred.
A λ/4 open stub realize a short, but it's narrowband.
The Radial stub is a λ/4 open stub with wider bandwidth.
Keywords:
- at connection point, Width shoud be small
- At the open end, Width shoud be wide
- At open end, corners should be avoided (reduce charge accumulation due to point effect), so here's why it's rounded.
For references, look on IEEE web site
stub radial
but how to design the R0 of Radial stub ?I find it not well with λ/4!
radial stub design
The length of the stub includes the pointed end which overlaps the main transmission line. Here is a very old free program to get you in the right ballpark.
radial stubs deisgn
thanks a lot
Added after 13 minutes:
But I still don't know how it calculate? Do you have a paper about design Radial stub ?
radial stubs
I found one paper and one book on this topics with this below title:
H. Atwater, “The design of the Radial Line Stub: A
Useful Microstrip Circuit Element”, Microwave Journal,
November 1985, p. 149-156.
and
B. Wadell, “Transmission Line Design Handbook”,
1991 Artech house Boston.London, p. 300-305.
but i have not none of the abow.
have you?
a radial stub
A radial stub is analyzed on the basis of radial transmission line theory. This is performed in cylindrical coordinates. I seem to recall reading it in Jordan and Balmain (EM Theory text book). It should also be in Harrington (Time Harmonic Fields text book, look in the chapter on cylindrical coordinates). The radial transmission line modes are writen in terms of Bessel functions. If you are comfortable with Bessel functions, the theory is very easy to understand.
formula stub radial
hello,
some say that the radial stub`s radius is not λ/4 but λ/5.
the design of radial line stub + mw journal
could you tell me how to design a radial stub, for example, how to choose the angle, how to get the length?
design microstrip & stub radial
microstrip stub radial
see paper by
1. March et.al in IEEE MTT..
2. Sorrentino et.al
They are good paper and you will know the procedure of designing
On eda board already ppl have posted these papers you can find them
radial line stub design
Hello
I am also interested in designing microstrip radial stubs to replace via hole.
The probleme is that I don't have access to the articles mentioned before of sorrentino and march and I didn't find it on edabord. If anyone has the papers or a link I would be thankful.
Here are the references I am searching for
A new simple and accurate formula for microstrip radial stub, Sorrentino et al
Planar circuit analysis of microstrip radial stub, Giannini et al
Many thanks
radial stub formula
hi
my project use radial stub. but i don't know in mean
i need a basic of radial stub
ex. introduction
thank you
radial stud design
Why don't you just simulate on your substrate:
input, short 50 Ohms-Line, T, same 50 ohms-line, output
on the T you put your radial Stub and vary angle and length.
Watch S11 or S21 and watch what angle, radius is best.
If you vary the angle, then length has to be altered, too.
the wider the angle, the more broad your bandwidth.
Also, you can put several smaller angle-radStubs for even broader bandwidth.
Try and error !
anyone can supply this paper?
H. Atwater, “The design of the Radial Line Stub: A Useful Microstrip Circuit Element”, Microwave Journal, November 1985, p. 149-156
thanks
I can't find it with internet.
Thanks very much
how about the angle of the radial stub?? what the suitable angle for f0=2.4GHz?? Is there any formula/equation to calculate it??
Hy there,
i' working on a amplifier, and the biasing networks I have chose are radial stubs.. I use these web page to design the stub " **broken link removed** ". I work's grate on the simulation, but i still can't find the equation for Zi. If i find it i'll post it. :evil:
Zi is the trace impedance of Ri, using TXLINE to calculate it.
Well people.... The sad thing is that the formula is not simple at all!!, but the good one is that I 'm leaving here a pdf where you'll find it. Hope it helps you anyway.
  • JMPEE-Vol32-Pg246-Gunel.pdf
Reactions: macunix and sushia
    V
    sushia
    macunix
