use of Timer 1 for enhanced PIC PIC16F1936
jean12
Advanced Member level 2
www.ntigltd.com
Hello there I am using PIC16F1936 on the point where I am,i need to use Timer 1 which provide the scale for Frequency and voltage division/Multiplication for my experiment,I now have difficulty in configuring this PIC to use the Timer 1 as a counter,see the codes below could any one help me to handle more this?
PHP:
BANKSEL T1GCON ;Gate control register for Timer 1 operation
	MOVLW 0XC0
	MOVWF T1GCON
	BANKSEL T1CON
	MOVLW 0X31
	MOVWF T1CON ;Timer one configuration and turn on
	BANKSEL INTCON
	MOVLW 0XC0
	MOVWF INTCON ;Timer 1 controlling register for operation
	BANKSEL PIE1
	MOVLW 0XC1
	MOVWF PIE1  ;Interrupr enabling bits values
The scale has to be handled for division and multiplication for V/F of an ACIM Motor!!
Thank you!!
You're operating the timer with external gate input, fosc/4 clock and 1:8 prescaler.
I haven't the slightest idea how it should work for V/f curve implementation... I would consider PWM setpoint arithmetics.
when controlling a three phase bridge(MOSFET IRFP460Z) ,I configured the PIC to operate in half bridge so that the two signals P1A,P1B are feed in one IR2110,and then the output of this is used to control the IGBT of the same bras (line),unfortunately I am not getting the output,when measuring with oscilloscope at the gate of the MOSFET I get the signal ,my bridge is powered at 20VDC,is this right or I am wrong in usage of those controlling signals?
Refer to the circuit of https://tahmidmc.blogspot.com/2013/01/using-high-low-side-driver-ir2110-with.html I made this three time and then I measure the output signal between the source of the MOSFET.
with HIN connected with the HIGH signal from the PIC (P1A) and LIN at P1B;I am using PIC16F1936.
Please advise!!
