adnan012
Advanced Member level 1
I think it 220 mains is isolated from isolated supply and ouput?
How Current transformer is reset?
One side of the incoming mains (U2) is directly connected to the negative dc output.
You can sim both GDT and CST in ltspice which is freeIs there any simulation available for current transformer?
U1 is directely connected to mains.
But i can´t find where U2 is connected to mains.
Klaus
its called current mode control. Its "related" to the secondary side because the current goes through the primary, then passes as flux though the transformer, then gets into the secondary, so its "related"In the Schematic current is sensed at the primary side, how can it be related to the secondary side?
As long as you rc filter it into the cs pin .Can i use shunt resistor at the primary side (it will effect the isolation)?
try and wind secondary evenly spaced round the whole core, then pass the primary through the torroid.How current transformer is constructed using ordinary (unknown) toridal core ?
