Do you mean the two transistor forward converter?, which I have indeed heard called "diagonal" in the pastI would suggest the half bridge diagonal topology
the peak current problem for the flyback is in the secondary not the primary. The bridge has an output inductor, which flows current continuously, so the secondary peak current for bridge vs flyback is lower (lower peak I for bridge smps).
Never heard of that before, or ever seen it happen., something to do with if the referred voltage secondary to primary, is greater than vin, then it can go bang.
yes this is indeed the problem, you can't clamp two different voltage sources to each other. At least , not recommended to try to due to it might smokeIt can NEVER reflect more voltage than the input voltage because its clamped by the two diodes
This sounds like a classic controller wind-up problem, its pretty typical behaviour when one control system takes over from another control system.My major problem with Battery charging is that, when i charge the battery using constant current of say 'X' (A) from converter and after reaching the output voltage of say 'Y' (V), I want to hold that voltage. But when I hold the voltage at 'Y' (V), I want the current to decrease from 'X' (A), In my case the current takes a shoot i.e. increases beyond 'X' (A) and then start to decrease. I'm using PI control separately for voltage and current, without any inner loop.
In CCM both the flyback and forward have a second order response, with the flyback also having that nasty RHP zero. From a control standpoint a buck derived converter like the forward converter is generally the easiest to deal with.While I agree with you that a forward converter has far lower peak current than a discontinuous flyback, it also requires a filter choke and the result can be something that can be far more complex to compensate. Poor transient response and instability can often plague forward converters, and can often be very stubborn to fix.
I don't understand what failure mechanism Basso is referring to there, having the figure he refers to might help.That's total nonsense.
The flyback energy will distribute very well without blowing anything up.
It can feed both the bulk input capacitor (via the clamp diodes) or the output capacitor (via the rectifier).
Flybacks with multiple secondary windings are extremely common, and the cross regulation is pretty good too.
The good Mr Basso is barking up the wrong tree with that one.
All very true.In CCM both the flyback and forward have a second order response, with the flyback also having that nasty RHP zero. From a control standpoint a buck derived converter like the forward converter is generally the easiest to deal with.
Just about any topology falls on its face if you hit the saturation wall.But keep in mind the diagonal flyback will fail if duty cycle is pushed past 50% due to saturation, similar to the forward converter. If the controller doesn't automatically limit duty cycle then a drop in Vin would definitely be a problem.
top of page 7 of this is talking about this particular failure mechanism of a 2 switch flyback...ti.com don't call it a failure , but just say that transformer operation is interfered with.....
Under steady state conditions, and nominal line/load conditions, yes. Not a robust design philosophy to ignore transient conditions and edge cases though.All very true.
But I suggested flyback, with discontinuous operation, and there is no reason to exceed 50% duty cycle with a suitable transformer turns ratio.
This avoids ALL of the above problems of RHP zero and second order responses.
Again, the reflected vout cannot exceed Vin, it can only be approximately equal to it.Thanks, I will now be very cringeworthy and bring up one application that the 2 switch flyback can’t manage because of its problem if it reflects back more voltage than vin……..
Agreed, it's not good for things requiring a very large duty cycle range like AC-DC converters.the “single stage, offline , PFC’d Flyback”…..for obvious reasons, this cannot use the 2 switch flyback, which is a darned shame as its power handling capability would have made it very good otherwise.
(I am still wondering what Basso meant by the Applause as in the above posts #12 and #14)
