The board does not carry 70amps, There is an external shunt that carries the current, The 0-75Mv comes in on JP2 and then the op-amp are set up to boost the voltage and convert the negative signal into a positive signal when the current is been drawn in the opposite direction . I will modify the Polygon so it does not go to the edgeGood point, its usual to ensure that no copper features are within 0.5mm (at least) of the board edge.
I can't see anywhere on that board carrying 70A lol
