ChangBroot
Newbie level 2
- Joined
- Oct 2, 2009
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- kaka
- Activity points
- 1,307
I want to build a radiation detector using GM Tube (SBM-20). The GM Tube requires 400 volts DC and I am using arduino board for data collections and manipulation as well as PWM. Arduino uses 5/9V DC. My DC-DC Converter is a simple boost converter like this. I have found several schematics for a boost convert using timer, but since I use Arduino, I don't need a timer.
I was able to convert the 5V DC to 80V DC using transistor 2N3904 and Diode 1N4005 that I had at hand. The 800kOhm resistor gave a few micro amps that I wasn't even able to measure with my muleteer.
My problem is that I can't find the name of the components so I could buy them. So, I need either a schematic with components OR list of Transistors and Diode that i could use with my schematic (No large components).
Any help is greatly appreciated. Thanks.
