T
treez
Hello,
The following (attached) LTspice simulation of LTC3723-1 Full bridge SMPS with synchronous rectifier driver does not work properly when the synchronous rectifiers are added.
The simulation, which shows it working fine without the synchronus rectifiers, and mal-functioning when the synchronous rectifiers are added, shows the problem.
The dead times for the synchronous rectifiers do not appear to be correctly programmed into the Ltspice device models, and there is thus large shoot-through currents through the synchronous rectification FETs.
Do you know why this is happening?
