How to use printf and puts functions in IAR compiler for AVR
mike2002
Member level 2
Member level 2
c/c++ programming
I*A*R FOR A*V*R
Hello,
Does anybody has experience with IAR Compiler for AVR?
I am having trouble, how to use printf and puts functions.
I did set BAUD rate and UART for MEGA8. Functions compiled fine but noting out on serial port?
Thanks,
:cry:
printf
hi .. i am doing this other way ...
sprintf(buf, "\nTempC= %d degrees C\n", (int)temp_lsb ); // print temp. C
sends(buf)
where
void send(char TX_Char)
{//this sends TX_Char to UART
UDR = TX_Char;
while(!(USR&32)); //wait while tx buffer empty
void sends(char *string)
unsigned int n;
for(n=0;n<strlen(string);n++)
send(string[n]);
i have never used printf directly to seriel .. always via register ...
regards
cancel
I*A*R FOR A*V*R
printf calls the library function putchar, which must be adapted for the target hardware configuration.
The function is supplied in source format in the file putchar.c
Look in the HELP for detailed description.
Regards
Re: printf
sends(buf)
where
UDR = TX_Char;
unsigned int n;
send(string[n]);
regards
cancel
What is the differece between using register and directly serial port commands?
puts & printf
Thanks to all of you,
I did revised putchar function and included to my code:
int putchar(int c)
if (c == '\n')
putchar('\r');
while ((UCSRA & (1<<UDRE)) == 0) // UDRE, data register empty
UDR = c;
return c;
Now all lib. functions related to serial I/O functioning.
I guess getchar() need to be revised also to get other way communication? :lol:
