omerysmi
Member level 5
I want to implement rs232 receiver in vhdl with FPGA Altera DE1.
I have try to write some code but I know that is not good, my main problem is that I dont know how to get an indictaion that new data(serial data) is coming..so actually what I did is to move each bit of the serial data to the out parallel data (8 bits) every rising edge of the main clock
This is the code I have wrriten (again, it's not good of course):
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity receiver is
port(Clock, Reset : in std_logic;
Data_in : in std_logic;
Data_Out : out std_logic_vector(7 downto 0));
end entity;
architecture arc of receiver is
signal index : integer range 0 to 7:=0;
signal inbuffer : std_logic;
begin
process(Clock, Reset)
begin
if Reset='0' then
Data_Out<=(others=>'0');
index<=0;
elsif rising_edge(Clock) then
if(index<8)
inbuffer<=Data_in;
Data_Out(index)<=inbuffer;
index<=index+1;
else
index<=0;
end if;
end if;
end process;
end arc;
