Dino1400
Full Member level 1
- Joined
- Sep 22, 2010
- Messages
- 95
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Activity points
- 1,941
I'm tryimg to simulate a temperature sensor that has 7-bit output depending on the input temperature from -40C to 125C. in spice (I'm using eldo which similar to Hspice or star-spice).
The issue that I'm having is how to change temperature with time (increase and decrease) to watch those bits changes because all what i can do now is to run a DC analysis .DC TEMP -40 127 5 which only increase in one direction or .Tran 0 10u at each temperature. Please if you have any idea to help thank you all in advance. I try to use .PARAM TEMP and define TEMP as a pulse didn't work.
Thank again
Thank again
