Shady Ahmed
Member level 5
I designed a 2 stage op-amp, the schematic is as follows (i used a vcvs as the error op-amp for now):
as i wanted to check the stability,
* First i plotted the bode plots (both mag & phase of differential output of stage 2) (showing that the DC gain is 40 dB, GBW = 180 MHz & Phase margin = 56 degree)
* Second i inserted diffstbprove in the CMFB circuit to check its stability, so the updated schematic is as follows
and the stb analysis plots are: (which indicates that it is stable)
Now, i wanted to check the differential mode stability , so i created a test bench as follows
However, the output plots from the stb analysis is weird !! here it is :
So, my question is , is any of the tests i performed wrong? should i only use the gain & phase plots of the differential output as the first test ? or should i depend on the differential mode test using the diffstbprobe? and why is the result very weird?
Please help me with some hints about the stability analysis and which loops should be tested & how.
Thanks
Thanks
