power calculation in VHDL
Arrowspace
Banned
Full Member level 3
How can I calculate power in my VHDL design ?
Power used by your VHDL=0.
VHDL is code. Maybe you'd like to calculate the power in your HARDWARE that's RUNNING that code? FPGA Manufacturers provide tools for calculating power based on frequency, number of toggling elements, etc. It's not that simple.
I have design a adder in VHDL , I want to know the power consumption of it, their too many paper on internet providing low power adder, but not providing information how they calculate power.
Hello Arrowspace.
It entirely depends on the device you are implementing the VHDL code in.
For example if it's a xilinx part you can use xilinx power estimator or if it's a newer part you can use Vivado power analysiser tool.
All you need to do is provide a synthesised netlist, ambient temperaturs, toggle rates of io pins etc etc.
In vivado you can add this information via the post implementation ".xdc"
Basically the tool will see how many lut/mux' or whatever are required. It will then calculate the power consumed with the components based on a specific duty cycle(toggle rate).
