deepsetan
Hi guys,
1. I know that this formula is only valid when L(fm) is in dBc/Hz. In SPICE simulation such as LTSPICE, the phase noise generated is always in in nV/Hz unit. Let say if the noise generated is 2.3505nV/Hz, how to convert this phase value to dBc/Hz? . I only managed to convert nV/Hz to dBm/Hz but I'm not satisfy with my calculation.
2. If my local oscillator is a 2.4-GHz oscillator, does it suitable to be use with GSM800 and GSM900? Do I need a new GSM with higher frequency to make it compatible with the 2.4-GHz oscillator?
