R
red_alert
I was experimenting a BJT buck converter using a SG3525 in a pretty uncommon configuration (PWM pulses through the VC terminal, outputs connected to the ground).
The schematic diagram is as follow:
The input voltage is 24V, the output voltage is 12V, the intended load current is 10A and the switching frequency is 25kHz. The BJT is a high power/high frequency PNP transistor.
Overall, the circuit actually works.. but as the output current increases over 1-2A, the BJT is getting really hot.
I checked the waveforms for the base signal and the rise/fall times are quite big. As the rise time could be shortened by a higher base current (I'm going to put another BJT in a darlington configuration), I have no clue on how to speed up the turn off process.
Looking at the diagram, the only path for removing the saturation charge is the B-E resistor (R1). That's because the SG3525 output (VC) is an open collector and it's actually floating in off state.
I even tried a schottky diode across base and collector to limit the reverse C-B diode polarisation (saturation mode) to a smaller value (schottky forward voltage) thus the BJT it's not going into a deep saturation.
Neverthless, the waveforms wasn't changed too much and the heat is still present.
I'm thinking of an additional circuit - to put a small BJT across the B-E of the main (power) BJT and force it into the saturation mode when the PWM signal is floating.
Does anyone have any other ideas on how to deal with this situation?
