ctzof
Full Member level 3
- Joined
- Mar 1, 2012
- Messages
- 157
- Helped
- 12
- Reputation
- 24
- Reaction score
- 11
- Trophy points
- 1,298
- Location
- Munich
- Activity points
- 2,516
Hello,
I want to design a USB connection from a chip to a pcie header. The problem is the differential pins of header is in the opposite direction of that of chip. So I have to create a via and change the direction of one line to another layer in order to connect the two pins. The topology of the components cannot be changed. So I have to do something with what I have. I know that passing one of the differential lines through a via to another plane isn't a good thing, and also I have to be careful to make the lines with the same length which is difficult this way. Is there another solution to this problem. The attached photo can show you what I mean.
