P
pauloynski
32 bit adc
I need to develop a 32 bit ADC (well, 27 bits is enough ). Input ranges from 0 to 10mV (but only 3mV are usable) and at least 20 measurements per second should be possible. I´ve googled a lot and found only 24 bits reliably (and costly) solutions. Input comes from a 350Ω load cell. Good stability, linearity and temperature compensation is a must. Furthermore, as I have a mcu (Atmega164) it needs not to be a single chip version. I´ve tried to use an AD8552 op-amp at the input stage (as a current integrating ampliier) with good results. The whole circuit is included in a feed-back loop chain in order to minimize drifts and off-set. The feed-back loop is controlled by the mcu firmware. It is almost working but I would like to hear more from you GURUS because I know that the topology I´m using is not the only one that could work. Any schematic, even without any explanation, wil be much appreciated.
