how to get positive voltage using Ad8221?
harris110
Newbie level 3
Newbie level 3
I have question how can i get always positive dc voltage using AD8221 IC.?
Give to the IN+ a higher voltage than on IN-
It´s not a very specific question. Like: how can i get my car to always move forward?
Klaus
I am using at the end of a bridge and one resistance of the bridge will always change. I think now you may understand. And i have to design a PCB.
Klaus
With that less information you can hardly build apcb.
Klaus
I have attached the circuit i hope now it will be clear. Here resistor with key C will vary.
No, it is not clear what you want.
If you change resistor C in a way that at IN+ is less voltage than on IN-, then the circuit must output a negative voltage.
Otherwise something is wrong.
It is like you switch ON the heating, but say you want it to become colder.
The circuit amplifies the difference of the two input voltages.
Forr example on IN- you have 3.0V.
If now on IN+ is 3.1 V you will see a positive value at the output
If on IN+ is exactely the same 3.0 V then output is 0.0V
If on IN+ is 2.9V you will see a negative output.
But you don't want a negative voltage. What do you expect?
Should the value be limited at 0.0V?
Or should it go positive? This is called a rectifier.
Klaus
