mnvelocitypilot
Junior Member level 1
Hi team!
I'm struggling to figure out why I keep frying a 5V regulator and a PIC controller on a very simple LED strobe system!
I designed two simple cards, one with a PIC controller, and the other with a linear current limiter (using an LM338) and a mosfet (IRF510A). The PIC just creates a flash sequence which drives the mosfet and flashes some Cree LEDs. My intention is to use this for both a flashing landing light and wingtip strobe system in my experimental aircraft.
Here's an instructable I published after getting the landing light to work:
https://www.instructables.com/id/LED-Landing-Light-for-Experimental-Aircraft/
Current limit is set at 5 amps, and the LEDs are flashed 5x with a pulse width of around 100ms.
The problem is... while my design is working just fine for the nose mounted landing light, it fails immediately when the same design is used for the wingtip strobes... on the first flash, the 5V regulator shorts, and the PIC controller gets fried!
I suspect the issue has got to be that the controller is mounted in the aircraft, while the strobes are out on the wingtips, and that the 15 feet or so of wire has enough inductance to create a high voltage spike after the 5 amp current pulse... However... I'd think that if that spike is there, it'd fry the mosfet, and not the 5V regulator/PIC controller...
So, I'm very confused. Any thoughts? HELP! This is making me crazy!
