Near Field Patterns in CST Microwave studio
S_N_A
Hi Everyone,
Could someone please help me with plotting the near field patterns in CST MWS, I know that farfield patterns can be achieved by using the field monitors but I am not sure if there is such a procedure for near field patterns.
Bests
You use the normal monitors (H,E), see the attached pdf:
  • Slides_Talk_10_4.pdf
Reactions: wave85 and S_N_A
    S_N_A
    V
    wave85
Thanks for your reply, I can't see the pdf, did you upload one?
Regards
Hi again,,
got the pdf, thanks a lot :)
Do you know if there is a way to find field at a particular distance from the antenna?
Bests
For example, you can use a 2D-monitor plane and change the distance from your design.
Reactions: S_N_A
    S_N_A
Thanks a lot once again.
BTW have you used Microstripes for near field analysis? When I typed in near field in CST help it gave me the Microstripes package as a solution which I couldn't figure out how to use! I tried it and it keeps on giving me errors in excitation of the model.
Thanks for your help!
Regards
What kind of errors? Post the messages please.
