Saulius Skeirys
- Joined
- Mar 19, 2014
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 43
Hello guys,
I am facing an issue, where I can't manage to work SPI interface connection between two atmega's.
Basically, I am trying to get data from slave avr uart input and send it to master uart pin through SPI.
I guess the problem would be somewhere in code (maybe opening SPI connection...).
If anyone could take a look and comment it, that would be appreciated.
Master code:
Slave code:
Just in case, proteus simulation attached.
THANKS!
Master code:
#define F_CPU 2000000UL //Define the MPU operating frequency
#include <avr/io.h> //Header file for AVR device specific I/O Definitions.
#include <avr/interrupt.h> //Header file for incorportaing interrupt handling faclity (not used here).
#include <util/delay.h> //Header file for incorporating delay routines.
#include "USART.h" //Defines C functions for accessing USART Module.
#define BIT(x) (1 << (x)) //Set a particular bit mask
#define CHECKBIT(x,b) (x&b) //Checks bit status
#define SETBIT(x,b) x|=b; //Sets the particular bit
#define CLEARBIT(x,b) x&=~b; //Sets the particular bit
#define TOGGLEBIT(x,b) x^=b; //Toggles the particular bit
void WaitMs(unsigned int ms);
unsigned char ch;
int main()
// unsigned int ch;
unsigned char ch;
/* Set MOSI and SCK output, all others input */
DDRB = (1<<5)|(1<<3)|(1<<2)|(1<<4);
/* Enable SPI, Master, set clock rate fck/16 */
SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0);
uart_init(9600); //Initialise the USART Module with the given Baudrate
WaitMs(200);
ch=0;
sei();//enable global interr
while(1) //Enter into a uncoditional while loop..
return 0;
ISR(SPI_STC_vect)
ch=SPDR;
uart_putc(ch);
void WaitMs(unsigned int ms) //Generate a delay of ms milli second.
unsigned int i;
for(i=0;i<=ms/10;i++)
_delay_ms(10);
unsigned char ch;
int main()
// Set MOSI and SCK output, all others input
DDRB = (1<<5)|(1<<3)|(1<<2);
// Enable SPI, Master, set clock rate fck/16, SPI MODE 1
SPCR = (1<<SPE)|(1<<SPIE);
//Frame format.
//sei();//enable global interr
ch=uart_getc();
uart_putc(ch);
SPDR = ch; /* Start transmission by putting data in SPDR */
while(!(SPSR & (1<<SPIF)));/* Wait for transmission complete */
WaitMs(50);
return 0;
unsigned int i;
_delay_ms(10);
THANKS!
