I'm simulating a horn antenna in HFSS. I want to plot the phase of E-field on a plane.How can I do this????? please help
Hi ghous001,
You need to create your own variable in the fields calculator. You can do this by selecting: E, then ComplexPhase, then Mag in the fields calculator. Save this expression. Then you can plot this under "named expression".
See "Plotting Derived Field Quantities" in HFSS help for more info.
