erchiu
Member level 5
- Joined
- Apr 7, 2012
- Messages
- 93
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Rome - Italy
- Activity points
- 2,082
Hi everyone.
i have an oven with an electronic board that not working
this oven have three electronic boards.
1) power supply
2) power (with relais)
3) control (with buttons and display)
what does not work is the power supply.
in input there is 220 vac but in output there is not 9.5 vdc.
i tryed to replace an resistor from 10 ohm that was broken, but after replacement it is broken again.
so i replaced the mosfet (F3NK80Z 800 V 3 A 3.8 ohm rds n-channel) with an mosfet n-channel type MTP6N6 (600V 1.2 ohm rds)
now i found the voltage in output but it is 12.5 vdc instead 9.5 vdc.
Can be the rds value of the two mosfet that is different?
else anyone can tell me what is the problem?
good weekend everyone
Regards erchiu
1) power supply
Regards erchiu
