gbugh
Member level 5
- Joined
- Mar 15, 2013
- Messages
- 81
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Fort Worth, Texas
- Activity points
- 2,234
Per equations and charts like this one:
is it true that Litz wire won't work at VHF frequencies, like around 110MHz?
If yes, is it still good to use something like silver plated flat copper braid for high power RF transformers?
Would it work almost as well to use something like 1/8th to 1/4 inch diameter soft copper tubing for a primary of a 200-300W RF transformer? I probably will need just need a single turn.
I'm thinking of using a -17 powered iron core else a type 61 ferrite. Is there a core material better than either of these for a very low loss VHF DC-DC converter or a VHF power amplifier? I know powdered iron is repeatedly recommended in all the ARRL literature but the right size of type 61 ferrite, should not saturate and could be smaller, yes?
73
AF5IE
73
AF5IE
