samy555
Full Member level 4
- Joined
- May 11, 2010
- Messages
- 207
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Palestine
- Activity points
- 2,963
I've designed an Emitter Follower stage working on a 3-volt battery and IC = 3.25 mA
I do the design so that the Output Impedance = 8 ohms because I want to run a 8 ohm load. I do not intend to actually run the circuit, I do it for study and analysis.
Her is the circuit and some of my calculations.
The input signal was 300mvolt 1kHz, and the problem was that the output signal was distorted as the following picture
But when I removed the coupling output capacitor C1 I got a clean output signal like this:
How can I get a clean output signal in the presence of C1??
Thanks
Thanks
